A friend of mine works at 3M and was able to get me the absolute best 2 sided tape I have ever seen. 3M manufactures it for their own internal for assembling other products they make. It works great for mounting ECSs, RX, and Battery packs.
What make this tape so good?
Its 1mm thick made of a pliable rubber. The adhesive is embedded into the rubber. Most 2 sided tapes are made of a foam rubber that has a super thin 2 sided tape mounted onto it. If you have ever removed something mounted with the foam tape you get a huge mess of split foam and tape on both mounting surfaces. If the foam gets soaked the tape just comes off and your Parts are flopping in the wind. With this tape there is absolutely no additional cleanup after you un-mount your part. It peals right off in one piece. It is rated at 10 lbs per square inch of mounted surface.
Its made of a pliable rubber so it will form to an uneven surface. The rubber will not soak up oil or watter insuring that your parts will stay mounted.
Rolls contain approximately 4 feet of tape. You get my FastEddy guarantee. If you try it and don't like it I will refund 100% of your money including the shipping fee to return it.
2-rolls $5.99 Shipping included
4-rolls $9.99 Shipping included
6-rolls $13.99 Shipping included
Order Here with PayPal
While I was checking them out I also found several rolls of clear.
So specify Clear or Grey. Clear will be good for mounting things to your body, Or your RCs body.
Quantity's are limited. First come, First serve.
It is the same tape as shown in the pic but doesn't have a retail pack.
