TC3 with cv-r bump start/starting problem's
Rooster
Does any one have a problem starting there on road with bump start box? what I mean is I always have to play with the throttel on the controller and try to push on the bump box with the other.the motor will not just start up in less I play with the throttel back and forth just to keep it running.I'm about 10 tank's in to the new o.s cv-r after it start's and run's for a while it stay's running.but after the motor stopes if I let it sit for to long it's back to the same thing palying with the throttel just to keep running,it there an easer way of starting a bump motor.I'm not new to nitro just new to the bump box and new to o.s motor's.thank's for the help in advance
hmmmm.....
I had a problem like this a looong time ago with my first OS 15 cv-r. Ended up being my engine settings. I'd give them a once over just to be sure (especially you LSN). LMK if that helps.
As Santana stated, that's a tuning issue. As long as my engine is primed, I can start it with no touch of the throttle.
