Tamiya Tnx problem stuck in first gear
David fildes
Hi guys hope you can help when I start the truck all four wheels move, I have set all screws back to factory settings which did not work, and spent hours adjusting the settings 1/8 at a time just in case. The thing is the car won't idle the wheels still go no matter what is adjusted (like quarter throttle) but what is strange it shifts into 2nd gear no problem??? Any ideas guys????​
From what you are explaining it sounds like your clutch shoes are worn out. Take the clutch bell (Gear) off the front of the engine and inspect the clutch and spring behind the CB.
Problem solved I'd say thanks for the help
Replace the cb bearings,use steel shielded type
blind4x4
24
1K
blind4x4
blind4x4
X
15
1K
Nitroman7888##
Nitroman7888##
H
hamedhbb
H
D
7
2K
Daltonator777
D
