Stringweasel
Good day everyone!
I played around with a Tamiya Nitro Crusher around 10 years ago. I was a typical teenager and pushed it too hard, my engine lost compression, and then it went to the shelf. Now I want to restore it and drive it once again. Although I have a technical mind my knowledge of engines and RC mechanics is very limited. I hope you guys can help. I'll probably keep coming back to this thread to keep asking questions.
The car itself wasn't driven for that long as I killed the engine quite rapidly. The suspension and everything seems in okay condition (to an inexperienced eye). The engine itself is stuck. The recoil starter (correct terminology?) doesn't pull at all. This is probably due to old fuel solidifying after 10 years.
My plan is to take it apart and clean everything. The engine I'm fixing replacing the cylinder, piston, and recoil starter. I still have the original manual for assembly, so I'm hoping to follow it in reverse. Is there some disassembly literature somewhere?
I have a few extra questions:
I'm sorry if some of these questions seem straightforward, but I'm really keen to learn.
Thank you so much!
- Will I need to replace the oil in the shocks? It says you should add official Tamiya oil. Is there a real-world alternative?
- What products can I use to clean the engine itself?
- Will simply replacing the cylinder and piston fix the compression
Thank you so much!
