AJay
Okay, running temps... What is the correct method. When I tune it for steady blue smoke and good response I will get temps of over 300 degrees... 3 hours richer and it will drop to 258 and drool, sputter, randomly die at idle and in general, run like a finely tuned North Korean jackhammer.... with a bent valve.
I have done the "header mod" and am running 20% Traxxas fuel. I take the temp at the "head protector", over the glow plug, and horizontally on the cooling fins. The glow plug socket in the cooling head is the temps I'm referencing here. The temps are taken after a couple of hooligan blasts down the street.
I'm tempted to just tune it an hour richer of best performance and stop worrying about the IR temp (I have the thermometer set at "74" I believe.. whatever the manufacturer recommended for anodized aluminum.) The performance and driveability between proper temp and just rich of max performance is TREMENDOUS... Am I gonna cook my new toy?
Toodles and so forth
You Pal,
AJ
You Pal,
AJ
