T Maxx Issues (again lol)
ozruul77
Recently I got an older T Maxx, long story short the engine didn't start. I replaced the engine with a new TRX 3.3 via the power up program. the engine starts right up but is very inconsistent, it will run just fine but ONLY with the glow plug igniter on the glow plug, after that it will stall. sometimes it'll idle with the glow plug igniter removed but will die shortly after that... I suspect it's a tuning issue, any help would be appreciated 👍
Tuning issue. If it dies when the igniter is removed try a new plug. Off tune can foul a plug.
I tried a different plug, barely any if not no difference. it's a lil cold outside so I'm assuming that's the issue?
I'm assuming you've broken in the engine?
What fuel are you using? How old is it? What percentage is it?
So a little one how glow engines work, which may help in your diagnosis. The coil of the glow plug has platinum in it; when exposed to methanol which is in nitro fuel and heat, a catalytic reaction occurs and that's what makes it glow red hot to ignite the fuel in the combustion chamber. I say this because you won't hurt the glow plug by leaving the glow ignitor attached while it's running. If the engine is cold, it is going to be difficult for that catalytic reaction to occur, which is why you need that glow ignitor in order to start the engine. On a high compression motor, you can sometimes even restart the engine without a glow ignitor if the engine is still hot. It's a common misconception that glow engines initiate combustion with compression alone like a diesel. We know that it runs with the glow ignitor attached, so we can assume we have a problem with the fuel itself, tuning or a bad glow plug. You've stated you tried a new glow plug, so we'll focus on the other two. Make sure to use NEW good quality fuel... Traxxas Top Fuel is terriblely inconsistent and can cause a whole host of tuning issues. VP Racing fuel is much better and I'd recommend it going forward. I'd also recommend using 20% nitro fuel over 30% until you get the truck running right.
If the fuel is high quality and new (hasn't been sitting on the shelf for 3 months opened), we can continue onto the next step which would indicate a tuning issue. The first step to any issue that we suspect is tuning related is to reset the carb to its factory settings. On new motors, I like to do this regardless as sometimes they aren't correct out of the box. This should be in the manual, if not you can find the settings for the LSN and HSN for your particular engine online just about everywhere. Typically, I like to set the throttle gap to 1mm using the "idle" screw regardless of what the manual states. Don't assume it's correct if you haven't touched the "idle" screw... pull the filter and check. This should eliminate the possibility of a lean condition causing issues with combustion. Also, be sure to check O-rings on the carb and make sure none are pinched, torn or cracked which could lead to air being sucked in. Even if the engine is new, always check. People assemble the engines, they can make mistakes during assembly. Make sure the bolts that hold the cylinder head to the engine are tight as well.
Now try and start the engine, you can leave the glow ignitor attached for a couple of minutes while it warms up. These engines will load up at idle, you will have to blip the throttle on occasion to clear them out. They will not idle on their own for very long. How is it idling? If it is idling high, this would indicate an air leak since factory settings are going to be very rich and it should be idling pretty low. Go back to the previous paragraph if that is the case. If it is idling so low that it wants to die immediately, you can lean out the LSN 1/16 of a turn at a time until you can get the idle up high enough that it will stay running. I don't like using the "idle" screw to adjust idle as it can cause erratic tuning, I have always just used the LSN in order to set idle with good luck for years now.
Once you get the engine running and broken in, lean the HSN 1/16 of a turn at a time until you don't see a difference in performance and then richen it an 1/8 of a turn. This should take care of the "half tank lean" problem the T-Maxx's have and make it so you don't have to keep fiddling with the carb halfway through a tank of fuel. Adjust the idle with the LSN as needed. If you adjust the HSN, you will have to adjust the LSN as well, since the HSN is what controls the total amount of fuel that is flowing into the carb and it will have an effect on the LSN. Just use your ears and listen to the idle, that will tell you what you need to do to the LSN. While I wouldn't recommend this tuning method for something like a full on race engine and maximum performance, for a TRX 3.3 it should work fine and I've never had an issue with any of the Nitro's I've owned running using that method. It is also pretty safe and should keep you away form any lean conditions that could damage the engine.
Ok, I will try what you said. this is a brand new TRX 3.3 and this is also brand new Traxxas fuel. I have already bought fuel and I do not want to buy any more fuel. thank you for your help
the engine hasn't been broken in btw, it's brand new so I'm trying to get it to actually run properly before break in...
You can use a heat gun to warm up the cylinder head some before you start it. This should help alleviate any issues with a cold engine, it'll also make your easy start system work a little less hard since that engine will be very tight for the first few tanks until break in is over.
got it, thank you a ton! another question... I have an Rx batt that works fine but I don't have a charger, I'm wondering if I can connect a 2s LiPo to replace the Rx battery. is this possible without any damage?
If you've verified that there's no air leaks and it won't run on factory settings. At that point it's going to be fuel related or there is something wrong with the engine itself. More than likely fuel related. Nitro engines are finicky and everything has to be "right" in order for them to run. Fuel quality has taken a nose dive in the last decade it seems like across all brands... Probably related to the fact most people are running electrics now. But, something to keep in mind. I wish you the best of luck and hopefully you get that thing ripping!
As long as your receiver and servo's can take the increase in voltage, it shouldn't hurt anything. Just make sure to use a low voltage alarm. If you're still using stock servo's, I wouldn't do it.
They also have LiFe batteries specifically for receivers. They operate at a little bit of a lower voltage than a 2s LiPo and are a safer option, especially if the electronics are old as they probably aren't designed to run over 6v. I'd still recommend using a low voltage alarm though if you got that route.
Ok, the servo system is a little old so I will probably replace it eventually. right now I just want to get it running atleast decently
Set the carb to factory settings.
Idle screw: .7-1mm
Low speed needle: Flush with the slide
High speed needle: 4 turns out from closed.
Heat the motor before starting. Heat gun, hair drier, or head warmer.
Start the truck up. Get it on the ground. And start break in. If the truck is constantly dying, turn the high speed needle in a 1/4 turn. Doing so should ensure the motor will run through break in.
I’ve broken in a couple dozen Traxxas 3.3 motors on tmaxx’s. The one consistent is they all end up being identically set once broken in and tuned.
Orientating yourself on the fuel tank size, 4 turns out is going to put the needle pretty much 12-1 o’clock looking down at the hsn perpendicular from it. It’s going to tune out after break in about 7 o’clock from that starting point. At least at 3000’ elevation.
Temperature and atmosphere will dictate fine tuning from here on out. But, it’s going to be real close to that in any temperature from 25-95 degrees.
If your elevation is lower, it’s going to tune out between 6-7 o’clock.
The low speed needle is based on your idle gap. But, I set mine at .70 or so and flush the needle.
This is going to be rich. So, once you get the high speed needle set, run the truck in and let it set idling for about 20 seconds. Shoot the fuel to it hard.
It’s going to come out of the hole. If it’s sluggish run the motor clean on a pass or two and turn lsn in another hour. Run it clean and let it set for about 20 seconds. This is going to be real close if your idle gap is .7-.8.
I can’t tell you the exact position of the lsn because that’s going to be based on your idle gap. But, if you stay between .7-.8 on the idle gap this is going to get you close on the lsn.
This will get the truck running and keep it running for fine tuning. There is a chart here some where on this forum that’ll walk you through the fine details of how to go from that to a great tuned motor.
The thing about the 3.3 motor is in my experience, they are very consistent. And if there’s nothing wrong like an air leak or a faulty carb, they are simple to tune.
The carb settings I suggested above are the same on the stock carb or an os carb. The motor and carb straight from the factory is actually a ginger of a combo.
I personally believe if you learn to tune and take care of your Traxxas carb, you’ll get everything out of the stock carb in reliability that an os 11 carb will give you. At least for a couple years.
I have both on 3.3 motors and if you will follow maintinence guidelines and not adjust around on that idle screws like a lot of nitro guys do everytime they run, you’ll be great.
Set the idle gap anywhere from .7-1 and don’t touch it ever again. Use the lsn only to adjust idle and take off.
For break in look up what OS suggests for their 21tm if you are having trouble getting it to run if you can’t follow what I typed. And, search up that tuning guide. You’ll be ripping around in no time.
Nitro tuning chart at link:
