Fully charged,as of rite now when i check the Gplug on the blue wire while cranking it wont turn red but then again i tryed that once b4 when the plug actually went it didnt turn red either,at that time the new plug made the truck run great but on the test when u pull the Gplug and crank it while sitting on the blue wire it didnt get red but the truck ran great...when i heat the motor with hair dryer it will crank longer and it wants to start but the motor wont stay long enough with a strong crank...are all the gears supposed to turn it the black case that the starter is conected to (like the big gear that the 1way bearing connects to in the black plastic case,,on mine it seems tight to turn)
---------- Post added at 6:27 PM ---------- Previous post was at 6:24 PM ----------
This is so frustrating...
---------- Post added at 6:29 PM ---------- Previous post was at 6:27 PM ----------
---------- Post added at 6:34 PM ---------- Previous post was at 6:29 PM ----------
also if i put the bad Gplug it and press button on the wand the Gplug lite dont come on but when i put the goog Gplug in the lite lites up so should be good,,but either way the motor wont crank long enough to fire it up...
