T-Maxx 3.3 Spur Gear (Stripping Problem)
circusfreak
RCNT Rookie
Going back to metal spur
I was running a metal spur for a while and it recently chewed up the stock clutch bell. So the guy at the hobby store and on here suggested to use a plastic one and make sure the mesh is right. Well, I did that, but within about 30 minutes of runtime, the plastic spur got chewed all to hell. My mesh was correct with the paper test, and the engine mount was very secure. So I just ordered a hardened clutch bell and will go back to the metal spur.
Correct me if I am wrong though, but I am under the impression that if the slipper is set correctly, that should be the weak point and protect the tranny gears. So if I have a metal bell/metal spur and any driveline binding happens, the slipper should eat it up. Isn't that how it is supposed to work?
Thanks,
Rob
TheBeastsOwner
RCNT Rookie
If you are having this problem now you may want to look in to a simple roll bar. This will prevent landing on the motor which keeps you from striping spurs and breaking motor mounts. Usually the rear 2 bolts strip from the mount on a hard landing. I wasted like 5 stock and 4 billet mounts before I bought this http://www.neweramodels.com/item.cgi?session_id=jgddmmyehmldfdyqpddoisvdtiugeqje&part_id=3273. I have not had a single spur gear or motor mount problem since.
The tmaxx 3.3 was also my first nitro, it has evolved in to a beast as it sits. Currently shelfed with a broke main shaft in the tranny. LOL
Get that baby FIXED. TMaxx wants to shred bro
TheBeastsOwner
RCNT Rookie
Look man I dont want to be pushy, but your problem is gear mesh not the material of parts. Either #1 the bolts arent tight enough or are moving, #2 you have stripped the rear bolts on the motor mount, or #3 your getting chassis flex, or #4 your landing upsidedown on the motor and the impact is moving the CB away from the spur gear.
Most of these problem can be solved by a roll bar as I suggested earlier. I havent had to change a spur gear in at least 6-7 months and I was eating them like lunch before.
When you use a steel spur you are just creating a weak spot and that is going to be the CB or the transmission. If you do it right you dont need a steel spur...
This is actually true. Good advice. I bought my roll cage and My T-Maxx the Beast don't ever chew gears up now. Oh, and i run it hard all the time full speed passes, jumps, grass you name it. But yes they really make a huge difference. Your spur gear is the weak point and best weak point as its cheap to fix. If you turn it metal the next weak point like he said is going to be much more expensive. Thats why i will always have my spur gear be my break point. Thats also why i have 5 on hand at all times. But it never chews them now.
TheBeastsOwner
RCNT Rookie
Much appreciated
Thanks to all that replied to this thread. I now have a roll cage installed and all is well. I have installed the aluminum Traxxas motor mount with 4 good mount screws instead of two. As indicated I had stripped the two back ones on my old motor mount. Loctite is the gear in this situation. Set it right from the bottom with the paper in between the spur gears and there will be no issue. Thanks again to all that helped me learn the right way of doing this. Hats off toall in this forum. Leaning is great!!!!!!!!
Newfienew
Just looking to learn
Heck yea man now go SHREDDDDD!!!!
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Thread starter Similar threads Forum Replies Date
bobaloohoo T-maxx spur gear lawlz Traxxas T-Maxx 5
Rangerrico32 E maxx brushless spur gear Electric RC 2
frickenjoey 3.3 T-Maxx 1/8 scale Spur gear mod Traxxas T-Maxx 12
frickenjoey 1m pitch (1/8 scale) T-Maxx Spur gear Vendors Lounge 8
3 t maxx spur gear? Traxxas T-Maxx 9
D Breaking Spur and pinion gears on Traxxas X-Maxx Traxxas X-Maxx 4
hulkmaxx MGT spur on a maxx Traxxas T-Maxx 3
C t maxx 2.5 an spur gears! Traxxas T-Maxx 1
Captain Chaos Cyber-Maxx spur / bell alignment Vendors Lounge 4
I New to T-Maxx's. Why am I chewing up spur gears? PICS! Traxxas T-Maxx 8
S t maxx spur gears Traxxas T-Maxx 15
Evan5266 Front tie rods for my t maxx Nitro RC 7
Shockbender98 More t maxx issues Nitro RC 4
Shockbender98 T maxx fuel issue Nitro RC 6
P T maxx identification help Nitro RC 2
S T Maxx 2.5 engine issues Nitro RC 19
NurturantQuasar T-Maxx electric conversion questions Electric RC 3
Tivum T-Maxx Classic Cage Traxxas T-Maxx 6
Tivum T-Maxx Classic 1.5 Parts Nitro RC 1
C Brand new T Maxx 3.3 Transmission issue Nitro RC 4
Mbjones16 T Maxx pico .21 Nitro RC 16
H X Maxx vs. Savage Xl... Monster Trucks 19
W T maxx 3.3 full throttle after 30 seconds idle Nitro RC 5
Scalise Reviving my old 2.5 Maxx, electronic upgrade recommendations? Traxxas T-Maxx 4
M Teaching my son how to Bash a Traxxas Maxx Monster Trucks 6
C Maxx 4s tires Electric RC 10
Peeeenuuutt Traxxas MAXX- a boat powered 10th scale MT! Monster Trucks 5
johnnydmd Weird-O Maxx RC Builds and Projects 20
croccodillo T-maxx Brushless conversion Monster Trucks 5
Crogers T-Maxx shocks keep coming apart Chassis & Drivetrain 8
meister1993 picco 26 maxx Nitro RC 3
G Traxxas X-Maxx : - Unleash the Beast Traxxas X-Maxx 25
rcjamjam X-Maxx lover ? This is for you ! Monster Trucks 3
RyanKeith78 T-maxx big block build Nitro RC 0
HEADSOFTNER X-Maxx needs a stronger kushdrive Traxxas X-Maxx 1
RyanKeith78 Traxxas T-Maxx big block build. Nitro RC 8
RyanKeith78 T-Maxx big block build Traxxas T-Maxx 15
_Kodiak_ T-Maxx 3.3 Desert Runner Build Nitro RC 1
T New to me - Traxxas E-Maxx 3906 Monster Trucks 6
T Halting x-maxx repairs Traxxas X-Maxx 4
Tmandman New 1/10th scale body doesn't fit Traxxas T-Maxx Nitro RC 3
N T-Maxx LRP .32 Spec 4 Build Monster Trucks 1
N T-Maxx 2.5 transmission question Chassis & Drivetrain 4
A Traxxas X-maxx opinion Electric RC 6
WoodiE Recommended Traxxas X-Maxx Upgrades Traxxas X-Maxx 0
WoodiE Pro-Line X-Maxx Trencher 4.3” tires Traxxas X-Maxx 5
I T-Maxx 2.5 overheating Nitro RC 4
WoodiE RPM Rear Bumper for T/E-Maxx Traxxas T-Maxx 0
Little chicken T-Maxx Going to upgrade my T-Maxx steering servo and Servo horn Monster Trucks 45
corycoleman T-Maxx front end Traxxas T-Maxx 0
