Ok, so I fixed up the problem with the carb not closing properly but the brakes still dont work well... Maybe its because I need to get a 6V Hump pack battery to strengthen the servos and a spring to replace the tubing? However they used to be much stronger...
The main problem thats been making me so mad since I first got the thing was the constant movement of the T-Maxx during idle. It wasn't as bad last year but now as soon as it warms up like I mentioned many times it the wheels keep spinning during idle and it will drive faster and faster. I noticed that if I pick up the truck the tires will spin faster and faster until it seems like the engine revs up to mid-full throttle and the wheels spin extremely fast. At this point I always return the truck back to the ground and it will continue to drive. (But slower).
I got the truck to idle perfectly without much jerking or anything at all for a while, until I did a few high speed passes...
I tried lowering the idle speed till the screw came out quite far (the idle screw will come totally out if you continue lowering the idle counterclockwise correct?), until the engine sounded like it would almost cut out and shut down during idle, than I turned it up a bit so it would run. This still does not stop the acceleration during idle! It only makes it harder to start when cooled off!
This is really bothering me and making every tank of gas seem like a diagnostics test! Its really not fun when you can't bring the t-maxx to an idle and have full control over it. This must have something to do with the clutch or gearing, any ideas? My hobby shop is always very busy and it is hard to get the guy to look at it right away.
