ColdBlooded
- Thread starter
- #41
When it comes to superchargers/turbochargers I am as close to an expert as you can get. I spent 10 years working everyday on them for everything from OEM Fords, Chryslers,Toyotas etc.. to every type of motorsport including road racers,drag racers,tractor pullers and even a 2 stroke Mercury outboard. From every diesel maker to staionary powerplant engines. I even did one for a Russian mine sweeper once.
Any performance increase you think you got was NOT from this supercharger. The simple facts are 1.The design and tolerances in the compressor housing simply will not permit the ability to build boost and 2.The supplied pulley system will not spool it fast enough to build boost if the design were good.
Wise men learn from other men's mistakes,a fool from his own. - H.G. Wells
Well. I never stated that I ( Think ) there was a performance increase.
I believe i said there ( Was ) one. Everything you've mentioned that you work on all run by means of a different science than a nitro engine. Sound/Pressure waves play a large roll in nitro that have no effect what so ever on larger scale engines. And regardless of your beliefs, Again science wins. Find a plausible explanation for the graph if you're so sure.
Readings Taken by A Dyno Max rc484 and computed by DynoSaur pc interface software..
And without the fools man would learn nothing. ( ME )
Bulkheads, chassis braces and some like to run shock towers and carriers. That's the only places you want aluminum on a Maxx. Rpm covers the rest. If you want your Maxx to rip, tune the engine properly. If you want over the top power, install a red dot. If you want a shelf queen or a pile of expensive junk, you outfit a Maxx in all aluminum and add a supercharger and nos.
Some good info here I will take and use. I've gotten my hands on an
all aluminum chassis. OMG at the weight but damn it looked pretty.
ANy way I will be going with aluminum shock towers, lower braces,
metal drive shafts, and every thing else will be RPM and carbon fiber.
I've found some nice sturdy ultra light chassis plates in carbon.. Look
good. Upgrading my shocks as well.. Already have most of the parts.
Will post pics when all my upgrading is done..
