Hi everyone. I need some help.
I have an MGT .21 with the 2-speed transmission. It is stuck in second gear and refuses to drop back down into first.
Here's what I've done to troubleshoot the problem:
1. Took apart the transmission and verified all of the parts are in there and in good shape.
2. Rebuilt the clutch.
3. Checked all the gears for any missing teeth (there are none).
4. Adjusted the little black screw in the transmission every which way.
5. Verified the 2-speed drive shaft in the tranny is straight and correctly attached to the little disk that has the set screws (can't remember the name).
All of the electronics and servos are working well, the engine runs great, and it will even switch back and forth between forward and reverse. But in both directions, it's still stuck in second gear.
Any suggestions?
Any suggestions?
