That large black gear is affectionately known as the "spur" gear. I don't advise putting your finger on it for long periods of time. And let me explain why. First, the reason a T-Maxx jumps and clicks like that is because of the transmission. There is another clutch inside the transmission case. And if you get the spur gear spinning fast enough, this clutch starts to engage. In a lot of cases, people set their idle high enough where this clutch is trying to engage, but not enough to get it to engage fully. Hence the clicking. So, by holding the spur gear you hold the transmission motionless and again, no clicking. BUT, by holding the spur gear, you are also holding the clutch bell with the pinion (the small gear on the engine) in place. More than likely, your idle is high enough where the clutch shoes inside the engine clutch want to engage. By holding them, you are forcing the clutch shoes to rub on the inside of the clutch bell which will heat them and possibly melt them.
The moral of the story? Reduce your idle speed. This will keep the transmission clutch from trying to engage, and your truck won't click or jump.
