I was way off, but I found this at Traxxas....................................How should I adjust the carburetor needles on my TRX Pro .15 engine?
The first adjustment should be your idle speed. Set your throttle opening to 1.5mm open with the throttle arm pushed all the way towards the head of the engine. Next, set your low speed mixture to 1 3/4 turns out from bottom. Last, set your high speed mixture setting to 2 1/4-2 1/2 turns out from bottom. These adjustments will vary a little from engine to engine. They are meant to be a guideline. Your engine, after it is broken-in, should be adjusted according to its performance.
