Well, you could just buy some decent AA NiMH cells at wal-mart (I use duracell 2500Mah cells) and buy this:
http://www.horizonhobby.com/Products/Default.aspx?ProdID=JRPC223
Granted, it's not a "quick" charger, but it's at a low enough current that it will help the cells last quite a bit longer than those harsh quick chargers that they sell in normal stores. IMO, those chargers that come with batteries in normal stores charge the batteries until they are far too hot. I don't know what Mah rating they burn at, but it seems to be a bit too much to conserve time for the buyer.
I've found that charging mine at 500Mah makes them last a lot longer. Both my receiver packs (2/3A 1100-1400mah and AA 2500Mah) and my transmitter hold up really well to a 500mah charge. I've used 1.5A to get them juiced up the first time, then after they peaked, I let them cool down and hit them at 500mah. I then use 500Mah before I go bash the morning of or night before to top them all off.
Been working well for me for quite a few years.
I've done the receiver plug pigtail mod on my remote in the past (Airtronics MX-3) and I use my MRC 959 charger to charge everything. Except for my heater cells.
I recently picked up a Spektrum DX3.0 which uses the same charge jack as the JR radios. I had bought the JR charger similar to the above one 8 years ago, but it was for NiCAD and was a lower Mah rating. I just cut the end off of it and wired it to a receiver pigtail and now use my MRC959 for it as well.
I even use my MRC959 to charge my 12V drill... does a heck of a lot better charge than the B&D wall charger it came with and in 1/4 the time. Almost made my drill feel new again!
EDIT:
I found a better one that charges 500-700 mah. Appears to have a switch:
http://www.horizonhobby.com/Products/Default.aspx?ProdID=JRPC221
Costs a bit more, but would cover you for receiver packs and your transmitter. Not sure if it can do both at the same time... doubtful.
EDIT... AGAIN!:
Found another that runs at a higher charge rate yet:
http://www.horizonhobby.com/Products/Default.aspx?ProdID=JRPC222
Honestly though, I'd go with the 500-700mah one. Buying both would be silly unless you want to charge your receiver and xmitter at the same time. Otherwise you could just get a charger like mine and do a bit of work installing a pigtail on your transmitter.
Mines outdated, but they have a MRC960 now:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRST9&P=ML
You just have to remember to always drop down the charge current before hitting start. It defaults to 3 amps which is way too much for AA's. Like I said, I set mine to .5A (or 500mah) and it works well.
Man... I'm a jabberbox!
