big jilm
Alright guys, I tore down one of tha revos and sealed the mill and carb, Replaced the fuel lines and checked the tank for air leaks.. Got everything sealed up tight and went out to run.
I had the carb set to factory and ran the truck for about 5 minutes.. I got the shift point dialed in and leaned the HSN out little over 1/4 turn. So I'm sitting at just over 3 1/2 turns on HSN and LSN is still flush..
I ran it for about 15 minutes pretty hard and keep a check on the temp.. Maxed out at 278 degrees which I thought was pretty good. This thing was scream'n.. Turned it off and chilled for awhile..
I went to run it a few minutes ago and within 2-3 minutes was hitting up close to 300 again... Turned it off ,let it cool and went back to factory settings. Fired it up and the temp shot right back up to 290 and climbing...
I'm really at a loss as to what is going on. I didn't have any wrecks or bumps to knock anything loose. I let the mill set for 2 days so I know it set.
I know every engine is different but what are some of the neddle settings you guys are using??? I thought I was already pretty rich.. I'm even running with the body off at these temps so I can't imagine what they would get to with a cover.. when I ran earlier it was about 90 degrees outside and the last run its about 85 so not a big change in ambient temp or weather conditions..
I'm Getting really bummed. I haven't ran either of my trucks for more than 15-20 minutes since I got them without having a temp issue.. I have tested both for leaks and didn't find any but thought I would seal them anyway just to give it a try.. I'm running 20% traxxas top fuel and its a fairly new gallon..Any suggestions???
