gnarkill
how does this steel spur: http://www.hpiracing.com/products/en/86806/
Compare with this spur: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXBK5&P=7
I am really getting tired of replacing plastic spurs due to melting. Before you tell me to mesh my spur and pinion right, They are correct.
Being that there is that there is a hub in the center oh Hpi's gear is that going to give that slipping action like a plastic gear would? I am not sure if the Robinson spur has a slipper pad in the back like the Hpi hub does.
Also, when a plastic gear strips, It doesn't break anything. What will the each metal gears do, or will both metal gears act the same.
Once again...
-Thanks
Once again...
-Thanks
