Starter Box ???
Are you talking about a bump start? If so then yes you can, that's one of the advantages of the bump start boxes, you can remove all other starters from you vehicle, which means less weight. However, most vehicles aren't set up for a bump start, you normally have to buy a bigger flywheel, one that sticks out of the bottom of the chassis.
Actually it depends on the vehicle. You can not use a bump start on a t-maxx, but most other vehicles you can. So what vehicle do you want to use a box for?
