Starter box!
TWOCANE
Clarksville
I had a pull start and it went out so I was going to do a roto start. Question... Can you use a box on anything? I have a tmaxx, and I have to remove the engine to put on the roto start. Is that right ?...help guys!
You can't use a box on T-Maxx , a starter box requires that you have access to the flywheel from the bottom of the truck.
You have to pull the engine anyways to fix the pull start, if you want roto start, do it while the engines out.
That is correct.....the flywheel on a Maxx can't be reached from the bottom. Roto start is a good idea I have it on all my bashers.
