Standard to Short Shaft conversion
a1m80t
Houston
Can someone give me a quick walkthrough on how to convert a standard size crack shaft to a short shaft? I have a HPI t15 and guessing all I need to do is cut the thing, but I’m worried how precise I have to be and if there is anything else I need to know.
thanks
Here is a good article from Team associated
http://aedownloads.com/pdf/cutcrank.pdf
If you have an SG type shaft, the clutch set up is different.
BTW the parts I gave you allow you to use either SG shaft or the Threaded type crank.
Jon
Thanks Jon, it doesn't look to hard to do
i have Threaded type crank
