Stance steering issue
Jarcher21
Stance stock servo went out. But the problem below existed with stock servo and with new servo. Stock Tx and Rx. Left turn goes way further than right turn. End points set and right side maxed at 120% on Tx. Any ideas how to correct or what the problem is? Thanks
Remove servo horn, get endpoints back to 0 L/R, and get any other trim or steering setting back to 0 or mid-point, then reattach servo horn.
This was done previously. And repeated/checked several times. Does not fix the issue. Left turn goes about 20-25° further than right turn. With horn removed, you can visually see the servo turning more to the left than the right. Was crawling today at park and 1 of the guys said to swap out Tx and Rx to see if it still did this. Will try but don't think this is going to change anything.
Hm, that's interesting. And nothing is adjusted on the radio? All setting middle.? If so, I'm not sure. I have not encountered this before.
