Retread316
Adrenaline Junkie
I dug up one of my old posts over on that "other" forum...someone was asking me about quality stainless steel screws...here's the straight answer:
OK - Just like everyone else I can't stand the cheapo screws that come with the T-Maxx (or any other RTR for that matter). I've been looking at all the "pre-packaged" screw kits from all the companies out there (RC Raven, T-D Motorosports, Teambluestar, and all the kits available on E-Bay)...
Screw Kits on E-Bay (Click Here)
I didn't feel like paying someone else to put together a simple screw kit - so I found a few lists and compiled my own. Then I ordered all the screws from McMasters. I will list all the part numbers here and on my site sometime in the next week or so.
I ordered 18-8 Stainless Steel screws, I was in the middle of rebuilding my Small Block when the screws arrived. WOW! What a difference it is to have an abundance of QUALITY screws on hand when building/repairing the truck!
Seems a bit pricey at first, but find someone to split the order with and you have way more (nearly TEN times the amount) than the pre-packed kits (some offer only 64 pieces, some up to 350)...for about the same price!
I paid $56.00 for ONE THOUSAND PIECES of very high quality 18-8 Stainless Steel, made in Italy fasteners! Min order is for 100 of each type and they're very nicely boxed individually and well labeled. You can select from MANY different material types (alloy steel, black powder coated, etc.)
Here's the site, the site is AMAZING!
http://www.McMaster.com Look under the Category of "Fasteners" and then "Socket Cap Screw".
The list:
100 - FH 3x6
100 - FH 3x8
100 - FH 3x10
100 - FH 3x12
100 - FH 3x16
100 - BH 3x8
100 - BH 3x10
100 - BH 3x12
100 - BH 3x16
100 - 3mm Nylon Locknuts
Here's a complete list of what the different pieces are for...as you can see you will have PLENTY for extra trucks, guys in your club, lost pieces, etc, etc, etc...
Flat Head FH
8 – FH 2x8 – Differentials
2 – FH 3x6 – Chassis to receiver cover base
2 – FH 3x8 – Front skids to bellcrank posts
8 – FH 3x10 – Chassis brace to front and rear skids
2 – FH 3x10 – Chassis to throttle servo mount
2 – FH 3x10 – Chassis to battery box base
2 – FH 3x10 – Electric start plug
4 – FH 3x12 – Front skids to front bulkhead
4 – FH 3x12 – Rear skid to rear bulkhead
3 – FH 3x12 – Steering linkage
3 – FH 3x16 – Steering linkage
8 – FH 3x16 – Front and rear shock mounts
4 – FH 3x16 – Rear toe control link
Button Head BH
2 – BH 3x8 – Chassis to steering/shifting servo mount
4 – BH 3x8 – Battery/Receiver cover to base
2 – BH 3x8 – Chassis to bellcrank posts
7 – BH 3x10 – Transmission halves
2 – BH 3x10 – Chassis to throttle servo mount
4 – BH 3x10 – Differential halves
8 – BH 3x12 – Chassis brace to transmission
8 – BH 3x12 – Front & rear bumper mounts
8 – BH 3x16 – Front & rear body mounts
6 – LN M3 Lock nuts - Turnbuckles, etc.
I did NOT order these - they're easy enough to get and you just don't need that many on hand:
1 – LN M4 Lock nut - Spur Gear
4 – LN M5 Lock nuts - Wheel Lock Nuts
And here are the McMasters part numbers:
92125A126 Flat Head 6mm
92125A128 Flat Head 8mm
92125A130 Flat Head 10mm
92125A132 Flat Head 12mm
92125A134 Flat Head 16mm
92095A181 Button Head 8mm
92095A182 Button Head 10mm
92095A183 Button Head 12mm
92095A184 Button Head 16MM
93625A100 Nylon Insert Locknut 3mm
The list:
100 - FH 3x6
100 - FH 3x8
100 - FH 3x10
100 - FH 3x12
100 - FH 3x16
100 - BH 3x8
100 - BH 3x10
100 - BH 3x12
100 - BH 3x16
Flat Head FH
Button Head BH
