ST PRO diff trouble...help
bashmaster
My friend has an ST PRO and is having a lot of trouble getting it working (Dura trash crap), the problem right now is that about 80% of the power is being being put on the left wheeel and 20%on the right. I'm assuming its a problem in the diff, but how would i fix that?
hlep is needed.
duratrax is weird with the max series, they used pressure fit hex washers similer to some kyoshos. tell him to crank down the wheel as tight as he can without stripping it. also you should ask him to check that the outdrive is good and tight as well.
yeah that was the problem, the hex wasn't tight on the wheel and the outdrives were loose as well. i think his main problem was that he didnt heed my warning and started upo and broke it in without any locktite, and it loosend everything up enough to cause major problems.
eh
heed your warning eh? or mabye you just did not tell him that he needed locktight...and you had no idea because your t maxx didnt need it....but hey o well its working now...or was...bambambaaaam
