Long day.... drove 10 minutes each way twice to my bash spot and maybe got about 50 feet of total driving in. To make matters worse only about 5 feet of that was under my control. First visit my electronics just died, shook loose a wire inside the on/off switch and then just decided to go on a little hike by itself. Fixed that and went back only to screw up my spur gear before it even got going.
I have zero luck with spur gears and its starting to bug me. I've only been out about 5-6 times and 3 spur gears gone. I search, I read, I've tried all the suggestions and nothing works for me. Full tight and 1/8 turn back, or 1/4 both end up burning out the center of the gear. Full tight and the teeth break.
Are there any other options for a slipper on a t-maxx? Like a full plate instead of just the two small ones? I saw this http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSGN1&P=7 but it says 1st gen trans only. Is that .15 versions only? Then there's this http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBJC7&P=7 which says it mounts to the engine?
I'm staying away from the metal ones since I'd rather have a $3 weak link in the drive train but this is getting frustrating.
