Originally posted by Willthethrill
let me try to explain this. when it is in the premier stage when it is just about to wheelie, the car shifts, and loses that momentum, at least for me.
I think I understand what you are getting at. With a different gear set, it doesn't rev high enough, then when it shifts, its got no more power until it gets up to speed, correct?
That being said I have a possible solution. That does not include gear replacement.
Adjust your transmission, so when you are in your power band, instead of shifting, and loosing momentum, it stays in gear and continues to accelerate.
This will do two things.
#1 Increase RPM at which it shifts, allowing you to use more of the engines RPM.
#2 It will raise the RPM's at which you enter second gear.
This will put you right into the power band of second gear immediately after the shift.
If the tranny shifts too early, you won't be able to use the upper RPM of your gear set. When when you shift into second it will be moving too slow for your second gear to work efficiently (no torque after shift).
Gears should be used to increase power on take off, or increase the top speed of your rig. Not to change the shift point, or usable rpm before or after shift
The shift point adjustment should be used to keep your engine in its power making range before and after the shift.
Does this make sense to you, or did I not understand what you are trying to accomplish?
