Spring rate question
GusMax86
RCTalk Racer
JC Kansas
Does any one have a clue what color springs might be the best when using the P3 rockers and push rods? The only tidbit that I have been able to find says that the long travel rockers use the sliver ones (Had the long travels on b4 upgrading). Will I be good if I stick to those or should I switch?
springs are a prefrence thing, if you like the way it drives on those springs then stick with them if yours is like mine on the p3 with the shorter rods it rides lower so the stiffer springs would probibly be better i mean it is a progressive rate rocker so you'll still get decent stability through light bumps and the stiffness to help responsive cornering with a lower CG but maybe not as good traction over loose terrain, like i said its a prefrence thing
I hear you... looks like I'll just have to wait till I get my engine and see how it goes. Thax
