Sportwerks .26 base settings help!
Clintd
Sayreville NJ
I just got a Sportwerks .26 and I can't find any info on the net about it. Could anybody please tell me the factory neddle setting's and carb gap. :doh:
I can tell you when I get home if no one else chimes in. I just don't carry my manual with me at work...LOL...
You should cary it around like a Bible :jk: Thank you. I'm going to bring this thing to work with me and adjust it there if you or anybody else post's the helpful info I need. Thank you and everybody else in advance.
OK, told you I'd shoot them when I got home. Base settings are:
HSN: 3.5 turns out from base
LSN: 2 turns out from base
Idle: Doesn't say in the manual, but usually 1mm open.
Set the idle screw first and then make sure you're holding the carb closed when you adjust the LSN. And remember, don't turn them in too tight or you'll ruin the needle seat.
OK, I'm off to run the Mayhem...
