- Bomb Pop Island
- Racing
I already have carpet tires. I have Proline pins in the rear and wedges in the front - they have so much grip, I will try different tire combinations between the carpet and stocks to get the right combination. I already have a brushless system and a faster servo. (Hopefully the 3d printed servo mounts and horn holds up) For carpet I am thinking about getting a MIP ball diff. I will also switch out some shock oils (I have the upgraded aluminum shocks)
These upgrades go for both carpet and clay: MIP driveshafts, aluminum steering bellcrank, aluminum camber block/pivot block, RPM arms, and some other upgrades
Most of those aluminum upgrades are from Hot racing
For clay racing: I have Jcon ellipse rear tires. I will also try the stocks (which are slicks now) with some tire sauce.
And then after all of these upgrades, It should be a fun carpet racer and a clay track basher!
Some other things I plan to replace is the rear suspension pins and C and D blocks. I will also replace the chassis because I drove the car outside alot and the chassis is so scrapped up. With a new chassis I plan to get a chassis protector too.
Also I am looking for transponder mounting locations if I do want to race.
