Some pics of my Jato :)
RusTLeRx350
PA
New Tires/Wheelie Bar:
Tires/A-Arms:
Wheelie Bar:
A-Arms and Engine:
nice rig! will that thing really do wheelies? hahahah lol
Thanks for the comment! :) And yes, it does...maybe a few too many. You can't really tell in the pics, but the rear wing is beat up pretty bad. It's even bent in half and I've ripped a hole where the screw goes.
that thing is cool, but i would get aggravated every time u punch it to the floor and it hops up.
Thanks everyone! I just threw some Stampede VXL Talons on the rear.
do they make better handling or traction i can't make wheelies on my jato i dontk know why :(
On road, these tires aren't good. Off road, they tear. It's extremely fun offroad with these, and it kicks up the dirt. And for wheelies, try leaning it out a bit. That MAY be the problem. Is the performance right now a big sluggish? If so, that is the case. If not, don't lean it out, or else you may run it too hot.
well i just want to have fun with it for now but when i read wheelies on demaan i tough i was goin to be easy as give full gas and make the wheele but i can't get in that point and what do i have to lean the high speed or low speed?
The high speed. That's what I did. On factory tune, I wouldn't get any wheelies. Then I leaned it out like, a little and then I got the wheelies on demand. I can't ever keep the front tires down, unless I accelerate gradually.
once ur truck is up to temp u could try to either richen or lean out the low speed needle. lean I do believe. if u pinch the fuel line after a few good passes the motor should run for like 2-3 seconds rev up and dye less then 2 seconds richen. more then 3 seconds lean. hope this helps u achieve ur wheelies on demand.
it might have to be richend I can't remember I would have to play with it. But I think adjusting the low speed will help you but make sure ur rig is hot and or running when u make ur adjustments to that needle. youl get it good luck!
my jato
here are pics of my jato and now i have many wheelies as i want thanks
Get prepared to be buying new rear tires monthly now. Lol.
I need to get some alluminum a arms and front bulkheads. First thing I broke was the front top bulkhead, a arm, and steering buckles. where did you find those a arms?
I picked them up at my local hobbyshop. They're Golden Horizons, and in my opinion, are a lot better than Integy. Integy's stuff is poorly made, plus GH offers warranty. You can check out their website at www.ghhobby.com
