slipping one way
JaReD116
RCTalk Qualifier
Ok on my losi xxx-nt the one way bearing just keeps slipping no matter what i do. I just keep cleaning and cleaning it, but it wont stop slipping. What do yo uthink i should do? Scuff it a little bit with a light sandpaper?
have you tried drilling a small hole in the top of your pull start & one at the bottom.put the nozzel that comes with the nitro cleaner it the top and give it a good spray.that way you don't need to tear it down every time.if that does not work replace the bearing and or housing.
would it be ok if i took out the one one way bearing shaft and shot cleaner into the engine where the one way bearing goes?
I don’t see why that would have any effect on any thing. Just let it air dry before you put it back together.
Ok i will try that I didnt do it before because i wasn't quite sure if it would be bad for it or not. Thanks
