Sirio .23 Factory Settings?
Temlon
Does anyone know the factory settings on the Sirio .23? I need the LSN & HSN settings if anyone's got them... thanks.
LSN 5-1/4 out ( flush with the throttle ball stud )
HSN 7 turns out
At those settings, the thing just pours fuel out the exhaust... is that normal? I'm having a hell of a time getting it to idle. I have only ran 1 tank through it so far, but I probably only got it to idle for about 10 seconds at most... is it my ignorance, or is this engine just a little work getting it going?
The screw that is right below the HSN (I assume is the idle?) ... what is the factory setting on that one?
Yup that is what it says. Do it! I went through 10 tanks of and it keeps making power!!!
there really is know factory setting just set it at 1mm opened when at idle and check to see if it closes when brakes are applid. It shouldn't.
sirio .23
I just installed the sirio .23, it came with like 7 turns out on the high speed needle and the low speed flush with the rod. It doesn't idle either, I turned it down to like 4 turns out on the hsn and it barely stays on.... wtf, did you ever get it runing right?
