Si
Ellarby
  1. Racing
Hi I have recently stripped 3 savage 25 spur gears looking at getting a metal one it's standard 49 tooth 18 clutch bell will all savage x 4.6 and that lot fit savage 25 along as there 54 or 49 tooth thanks
Use the paper method. Get a thin strip of paper, set your mesh, and run the paper through it. If it easily runs between the pinion and sour and looks like a crinkled French fry, then your good to go. If it passes through too easily, o is extremely tough to pass, then your mesh is off.
Okays thanks dude I think I tightened the spur gear bolt witch would do the clutch slipper to tight but what savage spur gears would fit like would a savage 4.6 and xl and that all fit the savage 25 thanks
