derrick87
Hey guys i got a question about shimming the bell. Ok well first off with the Novarossi engine i got there where 2 shims an and end screw a throttle linage clip aswell that came with it. Now the one shim fits over the shaft of the motor and the other does not. I'm assuming the one that fits over it is to shim the bell but what is the other one for? if its to go over the end screw after shimming it just crush's down. The hole for the shim is to little to go over the shaft and to big to be used to go over the end screw? I'm confused lol you can see from the picture of kinda crushed in. do i need a washer to go over the screw or is the head big enough to hold everything together?
http://tinypic.com/r/2pri9zt/9
