Sharpie Extreme Permanent Marker
ahr43
Military Veteran!
Military Veteran
Build Thread Contributor RC Showcase: 3
Harris County, Texas
Picked this off the pegboard at WalMart. Advertised as 'Fade Resistant in Extreme Conditions.' Also states it 'Stands Up Against Sun & UV Rays.'
Giving it a try accenting windows on the Typhon 'Clearly Crazy II' body. Thought it might be useful info to those of you that don't know of it or tried it. Cheers. 'AC'
Next time I'm there I'll have to look out for them. I need to do some parts of my rc4wd tf2
I tried using a sharpie and it held nothing against a paint marker. I did try with a regular sharpie tho and not the suggested extreme version.
The paint marker worked so well. The type you shake like a rattle can. I picked up a set of 5 for like 10 bucks on the Zon.
Used it for my fender flares, windows and other areas that needed touch ups. I originally painted the black parts (except window trim) with spray from the underside.
