Lunatic Racing
My Hyper 7 PBS pushes real bad going into a turn. My set up is as follows:
Diffs= (F,C,R) 4000,4000,2000. Center diff is a Spider and others are stock. Front shocks are 50wt. and rear is 37.5wt.
camber is set at 2 degrees on front and rear, 2 degrees toe out on front and 3 degrees toe in on the rear. I have the caster clips behind the front arms.
The car just doesn't want to turn when it has any kind of speed to it. If I am barely crawling it turns pretty good. I was told that my rear wing is a high down force Proline wing. Could this be my problem???? I was wondering if the wing is putting too much down force on the rear and making the front end lift and not get enough traction. My tires are Panther switch med/soft and the track is small, tight, some jumps, clay with pretty descent traction. Any help would be great. Thanks in advance.
