KnightAzul
Hi,
I am using the throttle trim on the transmitter to set the idle speed on the servo side. The question is: how should I be doing this?
The throttle arm on the carb goes from fully open (max air in) to fully closed (min air in). Should the throttle trim be set so that the throttle arm on the carb is fully closed, or should be open a little to get the revs up a bit?
Thanks,
KnightAzul
Thanks,
KnightAzul
