Here goes another question: Does the idle speed screw have to be adjusted every time the car is run? Even when my car is running fine, if I turn it off and try to restart it I have to speed up the idle for it to start. Also, I'm setting the idle so that the wheels barely turn when the car is OFF the ground so I dont melt the clutch. Is this right? Because I could have the wheels spin a little bit with the car on a box and then place the car on the ground and it still wont move. Which way is correct?
