Setting brakes on My savage 4.6
insutama
RCTalk Qualifier
Just wondering how strong are they brakes suppost to be because went i set mine to where i can push it with no gas applyed and it still rolls when i apply the brakes the wheels dont even come close to locking up is that normal ?
Tighten the adjusting knob for the brake tension. Pump the trigger for the brake, and you'll see it move. It's part of the throttle servo arm. If you still want more brake, replace the spring with a length of fuel line and adjust it to your liking.
just when i set it to tight the brakes are engauged even when i dont push the break
It sounds like you're going from too loose, to too tight. You need to find the spot where full brake will give you maximum stopping power, and neutral will not apply any brake at all. Don't expect to be able to lock them, only enough brake to slow it quickly.
ahh maybe thats my prob I'm try to get it so the wheels lock :)
