sealing the carberator
knall
For the NEEDLES the high and low speed needles.
What are you using to seal them?
I have seen people use "Associated Green Slime" anybody use anything else??
I know about RTV for the back plate and the carb throat.... I am talking about the needles.
THANKS!!!
I use RTV on the banjo fitting of the HSN to make sure it's sealed well. But otherwise, just the slime to lube the o-rings. If they start leaking or looking dry, I usually just replace them and put a drop of slime on the new ones to lube it a bit so they don't tear.
I was pretty clear with my question. THE NEEDLES , the adjustable high and low speed needles.
You guys are using RTV on em? how do you adjust em after it dries?
BLAGH!!!! That has been my question from the start!!!! What do I use on the orings BESIDES green slime!!
OH, OK, BESIDES green slime......Just any kind of light, clear grease, maybe like 3-in-one oil, after run oil, even motor oil. Do not use shock oil, as this will cause the O-rings to swell.
