Screw head snapped off
panpan
Brighton, UK
I was tightening some screws today when suddenly a screw mounting the steering servo to the chasis came loose. Then I saw that actually, the head of the screw came off from the threaded end. I am now stuck with half a screw stuck in and i can't get it out. The screw is flush with the chasis so i really don't know how to remove the threaded end bit... help?
Well... you can try taking a thin dremel cutting disk and cut a groove in the top of the bolt (may mar the chassis a bit), then you use a good hard tipped flat blade screwdriver to carefully back the screw out.
What truck is it? Usually the servo mounting pieces are plastic... and replaceable.
Brad what do you mean drill and tap?
There isn't enough of the screw sticking out to get pliers on. It is flush with the outside.
If i really can't get it out, then i could replace it i suppose. it's an EB4
I don't think that one screw is that important is it? There are three other holding the servo on
