Hey Roog! Following along on this adventure. Just think how good it will feel when you finally get it right.
Two thumbs up to the mate offering up an assembly for you to copy. What speeds is he getting out of this combo? His tether car is running at a different track? Are the running surfaces similar? Are the tracks surface ground for smooth running? Are tether tracks flat or are they banked? At speed (60mph +), any track imperfection is wont to induce vibration through the tires. Track surface itself could be a factor?
Going now from a 100mm to an 89mm tire? How will that effect your recently revised pulley drive ratio?
[ Edit: Another thought. Are you allowed to change the tether length? Perhaps your car is tethered to a part of the track it doesn't respond well to? If the track is banked, changing tether length will change load on the car and the tires. ]
Great build. Stick with it, you'll get 'er done. -AC
I am going from 80mm to 89mm dia, but as you say quite a jump. I can only hope that I can hold back the rpm and that it doesn't run out of torque.
The chap who leant me the wheels and donated the tires was running them on an IC car, his car typically get to 160mph I think, I believe he holds the UK speed record in his class. Buckminster is 21m in diameter, it is smoother and faster by design.
The surface of our local track is rough and its diameter 42ft, I am just doing this for fun so if I can get close to 100mph I'll be happy. Despite being invited to try out at Buckminster my car is just a mule for trying out ideas, I would be a bit self conscious turning up with a lump of angle, or as it has been named here: "Freak on a leash".
My heart is in making something that looks more like a vintage 1950's race car, IC or electric I haven't made up my mind yet.
The surface with the dykem on it... is it flat or tapered to create a pinch point on the outer lip of the wheel?
Looking at the tire that was clamped between them, there is a ring around the tire where that lip would be that looks like that was a pinch point.
I'll send a pic in a min, my phone has decided to do an update!
The wheel parts look parallel, the tire running surface is 4.15mm wide and the width at the root before the inner retained ring is 5.39mm, so the tire tapers from the root to the outer edge. the inner ring is 7.6mm wide so quite a bit to grip onto.
As I see it the wheel will grip the root.
I have some remeasuring to do!
