Schumacher Cougar 2000 long rose joint
PhilMac
Hi,
Does anyone know if there is an alternative, or source, to the long rose joint on the schumacher cougar 2000. Part number t1188 or u822r, depending which part of the manual you read!
Any help will be great fully received
Phil
after doing some searching. I finally found out what your after a tierod end ball joint.I know theres a rc parts supplier (forgot name so sorry) my local rc shops have them in stock just have to know what the thread size is you attaching it to.?
https://www.bing.com/search?q=rc tierod ball joint&qs=n&form=QBRE&=%eManage Your Search History%E&sp=-1&lq=0&pq=rc tierod ball joint&sc=10-20&sk=&cvid=2BD159A6F87E4F61BC5D7ED7D073222A&ghsh=0&ghacc=0&ghpl=
Those are made to mount with a stud. The kind he needs snaps over a ball stud. His could be converted of course if he buys the correct stud.
Measure the ball they attach to. That will tell you which size you need. Likely a 3mm, but who knows.
Look here for the correct replacement
https://www.amainhobbies.com/search?cID=&s=ball+end+link
I attached the manual here in case you need it.
Hi tntpoof,
Thanks for that, I will have a look at your link and do some measuring.
