savage x 4.6 throttle problem...
cmzm
Hi guys l have a savage x k4.6 the problem is that every time I press the brake pushes the throttle inside . (when I hit the brake it closes the carb.)
I try to reposition the servo horn, I also cut a little servo saver spring the one underneath the servo horn but I still have the same problem, any recommendations.
I don't know what to do. :\
when you hit the brake it closes the carb? is that what you mean? not quite grasping what you mean
try this. take the throttle servo-saver off the servo. turn on your Transmitter, center the throttle trim button on the transmitter, hammer the throttle a couple times to get servo centered, then re-install the servo saver on the servo. now you have your fine tuning ability back.
If you're saying it shuts off the engine when you apply the brake you need to adjust the idle screw while holding the trigger in full brake position.
