Hello All,
First of all thanks for taking the time to read this. It seems that I am having a problem with my Savage and would like some advice. I got it last week and broke it in the engine. So far I have put about 1/2 gallon through it and haven't really pushed it yet. I went to run it in the back yard last night. I started it up and mashed the throttle but the truck barely moved. The engine revved up but not much else. I took off the body and watched it as I opened the throttle. The clutchbell spun as did the spur but not any forward motion. I shut it off and pushed the spur gear by hand. It didn't slip and the truck started to roll forward a bit then clicked and lost forward motion. I tried it a few more times with the same results.
I know I read about this symptom somewhere else but can't seem to find it again. Should I start by looking at the diffs or should I be looking in the tranny? Any advice is appreciated. Also, I noticed on earlier runs that after the fuel is almost gone the truck doesn't want to accelerate like it used to. It seems like the clutch isn't engagine properly. However, I think this is a separate issue.
Thanks,
Ron
Thanks,
Ron
