Clintd
Today I did the savage over. I bought savage SS duel disk brake setup, Ofna aluminum clutch shoes and the new SS steering setup. Everything worked perfectly. The only thing I did different was the steering. Instead of using the plastic center link, I used one from integy. I also didn’t want to use the screw pins that just threaded into plastic. So instead I used pins from a Kyosho inferno MP7.5 and nuted the other side. The only other thing I had to do was notch out the frame so that the nuts would not hit. After all the work the truck pulls wheelies again, will stop on a dime and give you 9 cents change, and takes turns extremely well. Check out the pic’s and you can see how much turn radios it has now. So what do ya think?
These are what the pin's look like
