I've run through about 5 tanks an have just started beginning tuning after following break in instructions. Truck absolutely screams an is very easy to time but it dies when I apply brakes. Should the clutch need adjusted or what?
Your idle gap is too small, open it up just a hair with the needle screw. Pull the air cleaner off and look at the gap, when you hit the brakes it should never close all the way.
that is what i was leaning towards, maybe a bad glow plug. He just did the brake in and i tell ya i seen some crazy things from a glow plug that was starting to fail.
I do the same, i got a hand full of extras. If the op has not got extra plugs i would go get a few . I agree to threw them a way i had buddy who would hold on to them. I told him you do not want to mix good ones with ones that are poor.Yup. After break in I usually just toss the glow plug out and put in a fresh one.
I find some people will use the trim on there remote to lower idle speed but for me i just do it on the motor.
yeah , once again like i said in my post , lol check the gap or glow plug.That is how you are supposed to do it. For those new to nitro...you should never use throttle trim to set your idle, as that is not what's for.
Easy rule of thumb: when you brake there should be no change in the 'gap' (i.e. it should not close any further than when throttle is at neutral). Easy test is to idle with throttle at neutral then apply brake. If you hear idle drop (or engine shuts down)..you know your trim is off. If you find yourself in a situation like this, always remove servo horn...put trim back to neutral and start over. If you need to fine tune anything, do via your link setup.
I adjusted the idle screw a little bit. Gap was way to small. Also trashed my old glow plug an put a fresh one in there. Now truck works perfectly! Thanks for the help!
Check to make sure your clutch bearing are good. If they are locked up then putting the brakes on will kill the engine.
Lee
Read the previous posts, he fixed the problem.
