Savage aluminum linkage parts...
cvec7
Gone - bye bye.
Anchorage
Ok, I've looked around but I cannot find these parts in aluminum. I need the "L" type servo arm that goes near the fuel tank, and mounts on that post near the fuel tank and behind the roll-bar. And, I need an aluminum rod-end for the brake rod that sticks up at a verticle angle. I know I've seen the aluminum "L" arm somewhere before, but can't remeber, and I don't think I've seen the al. rod-end I need before.
Thanks in advance.
Ok, thanks, that's what I was looking for, now the other thing is an aluminum equivalent to stock. According to the manual, all it says is "rod end" and it's the one that is used on the brake lever. You know coming out of the tranny is the brake camshaft, then it has the little black lever/rod sticking out at a verticle angle, then it has the plastic rod end on the end. I need just an aluminum one.
Will this work?
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=38185#ilikepictures
Possibly if you attach it with epoxy or JB Weld or something...The tie rods are a larger diameter so the threads in the brake lever will be to small.
Who needs brakes anyway??? Besides, it's cheaper to buy new bumpers and bodyposts. :jk:
