I’ll be honest I don’t have a slash but if you emptied the diff and it had silicone fluid, I would use fluid and not grease. Grease doesn’t provide the tune-ability like silicone oil does. Grease is just that…. Grease. It won’t kill your diff but I think you are missing out on some subtle changes to the way the car will feel or drive. You can tune or hone in on the perfect set up for sand with silicone oil in the diffs.
I wish I could give you a magic number on what to start with but I can’t, I don’t run my stuff in the sand because it’s just not the terrain I have available. Start with stock recommendations and what I recommended earlier and go from there. Pretty soon someone will ask this same question and YOU will be the one telling THEM how they should set up the truck, it’s all part of this hobby. LEARNING!
Thicker oil is more locked, thinner is more open.
Tekno has a good guide on this and
@bill_delong has posted this info many, many times. Do a search for some set up guides and most of all good luck! Tell us how this goes.
