Rusler.
jato1229
Took my kid out today for some bashing. nice jumps alot of dirt flying, etc. toward the end of the night we heard a clicking noise when we gave it gas,. a short while later my boy says the truck starts to turn under heavy acceleration. seems mayb one rear tire is turning faster then the other. what do u think.
I think you may need to inspect the transmission. rotate one wheel by hand and see if the other one spins the opposite way. If it does and you dont hear any funny noises then I'm not sure.....you may want to check the steering trim on the TX to make sure its set where it should be.....check and make sure the front tires arent loose and wobbling. If its none of that I would open up the transmission for a visual inspection. Thats about all I can think of atm.
If I turn 1 wheel by hand and the other wheel does not spin, then what?
sounds like you have a gear stripped in there...id tear it down and find out what the problem is...shouldnt be that big of a job on a rusty...
ok, so i took it all apart. all the gears look good, however the top drive gear ( 3195) is kinda loose with the idler gear ( 3696) seems there is play in the 2 gears. like i can move the top drive gear side to side alittle. new at this please help.....
