RTR Nitro RS4 3 Evo Upgrades
bmw328i
I have a evo I just replaced the stock Exhaust for a ths Racing Exhaust. I also replaced the stock air filter for a hpi high performance Air Filter. So know I have to tune it again. Cause it's running faster but I think the Engine it's getting to hot and it shuts off. it turn on again after it cools off. Then i'll do the same again. What you think the problem could be. What is the right temp to be for this car. Thanks
THS1010R Mounting rod.
Mine is doing the same thing and I have installed the same upgrades as well, but my question is about the mounting of the exhaust tuned pipe. What is the correct way to brace the pipe down using the mounting rod that comes with the THS1010R tuned pipe? It seems to be touching up against the fuel tank and want to keep it away from the plastic fuel container.Also my orig mounting bracket that the orig pipe screwed into does not match the tuned pipe I replaced therefore leaving the pipe really close to the fuel.Any ideas as to how to properly mount the pipe using the mounting rod provided? Do I have to cut the mounting rod? :cheers:
