Rs4-2 & Os .15 -- Setup Help Pls
wigsplittah
What's up everybody,
I recently purchased a Nitro RS4-2 sedan which came with the stock FE 15. Once I was bored with it I swapped it with an O.S. MAX CV-R .15 - it has plenty of power =)
it wasn't handling right so I deceiced to break the car down and check everything out. When I got the shocks, the front -- right side shock had no oil, the blatter wasn't on correctly, the shock shaft has deep scratches, etc.
So I'm going to rebuild all of my shocks and I wondering if anyone knew of a decent setup with the O.S. 15 for basic "parking lot" cruising, I'm not racing or nothing serious, just having fun.
I was thinking -- stiffer springs and thicker shock oil (60wt/50wt?), since the car has more power now? I'm pretty new to this and I would like to set it up right since I have everything apart.
Thanks in advance for any help.
Can't offer a setup, but you know, you might wanna consider just getting the factory threaded shocks. They cost about $35.
I guess that would make sense since I would be spending about the same to rebuild all 4, but if I add aftermarket shocks in the front, I'm guessing I should do the same for the rear? I found a set of hot bodies aluminum shocks for $20 shipped on ebay just now, I might go with those, what do you think?
If anyone could still recommened any setups that would be very cool. I know you can improve the handing big time by harding up the front and a slightly softer rear, but I'm not sure what color springs, oil wt, etc.. I'm a newb :)
thanks!
Well i've also got an RS4 2 and will be buying some threaded shock bodies whenever I get the money. The HPI ones were meant for the HPI Proceed so they're probably pretty overkill for your application. They are a lot better than the Hot Bodies one. The HPI's will have parts more readily available in case you need to rebuild them. Go with the HPI's
The stockers are fine just rebuild them and add some 60wt front and 50wt rear with HPI purple springs in front(super firm) and blues out back(firm). I run this set up on a couple of my RS4 -3s. If your car dosnt have adjustable turnbuckles and tie rods buy them also major diff.
thanks for the advice guys. I did end up getting purchasing 4 hot bodies shocks from tower hobbies. I will rebuild the stock shocks too and keep those as backups. I also purchased some 50wt and 60wt. I didn't get any springs, I wasn't sure if HPI springs would work with hot bodies shocks. I'm sure it'll be fine tho.
Those stiff springs with thick oil is great provided that where you plan on running has plenty of grip. On a prepped surface this would be a good set-up. But for just parking lot bashing where 1/1 cars have dripped oil and there's dust abd other debris, you gotta go soft. I run a RS4 2 and althought is sounds awful soft, I run the white springs out back, yellows in the front. #2 pistons on all four corners with 20 wt oil. This causes a lot of body roll (oh, forget sway bars. they're useless) but you NEED the weight transfer when there's a limited amount of traction. I also run the Pro Compound X pattern tires with black inserts. Run slightly more negative camber with this soft set-up because when the chassis rolls it will plant the outside tire as the suspension compresses. I also use the carbon fiber upper deck because hard brake applications with the stock flimsy plastic pieces flexes the chassis and affects handling. I wouldn't suggest upgrading to a Racer 2 front suspension until you first stiffen the chassis, but you should have plans (if you want to wring the most out of this car) to make the Racer 2 upgrade. By the way, I am using the stock shocks that came with my RS4 RTR. I know the threaded units are cool and fancy but that's money you could spend somewhere else. I invested in a set of the HPI spring shims that I use if I want to increase spring rates instead of the threaded ones.
A lot of people are going to tell you that this set-up is too soft and for all out racing it is. But for parking lot bashing it's hard to beat.
When I run a rough parkinglot, I found with a soft setup my chassie was contacting the surface to much causing drag and inconsistant handleing? Thats why I run stiff?
I see what you're saying and it's true that this setup does bottom out easy :yes: . I pick parking lots that are smooth. But even at that I wouldn't go to the other extreme with super thick oil and strong springs. Maybe yellow springs on the rear and reds on the front. And #3 or #4 pistons in the shocks. :radio: I'd put the lower numbered piston on the end I'd want the most traction on. #4s on the front will tend to cause the front end to push out a little more where if you put them on the rear it will break the rear tires loose first. I prefer the front end to push out and then I get it back by easing off of the throttle a little. Once the rear end steps out on me I usually can't get it back. And if I do, whew :puke: , it gets ugly
